Angled Holes - New to OnShape
I need some direction on how to go about making an angled hole.
Assume you have a cube 2x2. I want a 1/2" hole diagonally from the left,rear,top corner diagonally through the cube exiting the right, front, bottom. I'm stumped (or stupid). Here is a quick drawing from TinkerCAD (sorry, I know it's cheesy! to illustrate what I mean.
The answer to this is a bit convoluted.
With a some help from @konstantin_shiriazdanov, here is my take on things.
For the hole function to work we need a sketch point normal to the direction of the hole.
For a sketch point we need a planar surface (usually an existing plane or the flat side of a part, but that's no good here)
So we need a new plane.
Now I didn't want us to have to do any math(s) (to say rotate a plane by an angle) because if we change the cube later into a cuboid it'll fall over.
So in this example we have:-
(a) 3D fit spline, to pick up the ends of the hole and determine the normal direction.
(b) A "Point Normal" Plane created on the end of the spline
(c) A sketch on the new plane with the vertex of the cube projected onto it.
(d) The hole function used to make the hole.
https://cad.onshape.com/documents/4e661419b9a6f9eafd2e4b5e/w/02a4904ee81e2ea7d38c5e85/e/47cb2e3eb5ff2ec2ae1c6c4b
The 2nd example shows the same method used between a couple of points on the faces of the part instead of the corners.
It's usually at this point that @philip_thomas jumps in and says you can do that in 2 steps not 10, but at least it's a start!
Cheers,
Any fewer steps would involve a custom feature
You're welcome.
Cheers, Owen S.
I know this is an old post, but just to give another idea:
you can also use a plane, sketch out the profile and use revolved subtractive. at least that's what i usually do in this cases.
I used create 3 point plane, sketched the hole and revolved.
