Use of @ in comments to notify a specific user
bill_danielsbill_daniels Member Posts: 277 ✭✭✭
” sign to direct a comment towards a specific user."
Huh?
  Exactly how does that work?
I tried and nothing happens.
    Scott_WertelScott_Wertel Member Posts: 9 ✭✭
    Start by typing @ and then the first few letter of their username.  Then, pause for the list to appear, and select their username.
    @bill_daniels
    Principal & Co-founder
    Aerospace Research & Development Group, LLC
    www.aerornd.com
    I believe the list is populated from user you have shared Doc's with in the past, so if you've not shared then the list will be empty.
    Owen S
    awkawk Member, Onshape Employees, Developers Posts: 78
    Owen is correct - the list of shortcuts (trigger by using the @ when typing in the comments field) is seeded with those people the document is shared with and others you've shared with in the past.
    Director of API, Appstore, and App Partner Technical Support
    Weird, because I was able to use it for @bill_daniels and I've never met the guy before this thread.
    www.aerornd.com
    grochinogrochino Moderator, Onshape Employees, User Group Leader Posts: 44
    Andrew and Owen are referring to commenting from within a document.
    Frank_WhiteleyFrank_Whiteley Member Posts: 1
    I received a comment from you via e-mail from alerts@onshape.com.  Looks like a message on a bid.  I could not find it inside the project.  I have received other alerts.
    michael3424michael3424 Member Posts: 676 ✭✭✭✭
    Perhaps the reply you wrote to his post was your means of introduction.
