Use of @ in comments to notify a specific user
bill_daniels
Member Posts: 284 ✭✭✭
” sign to direct a comment towards a specific user."
Huh? Exactly how does that work?
I tried and nothing happens.
Start by typing @ and then the first few letter of their username. Then, pause for the list to appear, and select their username.
@bill_danielsPrincipal & Co-founder
Aerospace Research & Development Group, LLC
www.aerornd.com0 -
I believe the list is populated from user you have shared Doc's with in the past, so if you've not shared then the list will be empty.
Owen SBusiness Systems and Configuration Controller
HWM-Water Ltd0 -
Owen is correct - the list of shortcuts (trigger by using the @ when typing in the comments field) is seeded with those people the document is shared with and others you've shared with in the past.Director of API, Appstore, and App Partner Technical Support0
Weird, because I was able to use it for @bill_daniels and I've never met the guy before this thread.Principal & Co-founder
www.aerornd.com0 -
Andrew and Owen are referring to commenting from within a document.Scott_Wertel said:Weird, because I was able to use it for @bill_daniels and I've never met the guy before this thread.0 -
I received a comment from you via e-mail from alerts@onshape.com. Looks like a message on a bid. I could not find it inside the project. I have received other alerts.0
Perhaps the reply you wrote to his post was your means of introduction.Scott_Wertel said:Weird, because I was able to use it for @bill_daniels and I've never met the guy before this thread.0
