Colors in Featurescript
marcus_bernsteinmarcus_bernstein Member, User Group Leader Posts: 35 EDU
Hey Onshape people-
I'm working on a project for competitive robotics and it would be pretty sweet if I could set the color of a part/extrude in featurescript. The standard documentation doesn't seem to have functionality for it and a quick search didn't turn up anything, but any help that you can provide would be much appreciated!
I'm new to the forums so sorry if I missed anything big or didn't catch a previous answer to this question.
Any chance Onshape is looking for interns?
Philadelphia User Group Leader
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,254 image
    This is not yet implemented, sorry.  It is planned soon, though possibly not soon enough for your project...
  • vikram_babu080vikram_babu080 Member Posts: 4 PRO
    Just following up on this question, has this been implemented yet? I am interested in changing the color of a line if have created using FeatureScript (specifically using to OpFitSpline function).
    Why the down-vote?  :|
    @owen_sparks be carefull, look like you have a musterious foe. The more posts you write the more downvotes he would be able to make :D
  • emagdalenaC2iemagdalenaC2i Member, Developers, Channel partner Posts: 864 ✭✭✭✭✭
    Unfortunately, we can't know who votes, but I give you 2 up votes in compensation
    I've even looked over if there is something about it in the vanilla forums, which I think is the one used here... but without results
    Un saludo,
    @vikram_babu080 @marcus_bernstein
    This is possible through the new `setProperty(...)` call:
    https://cad.onshape.com/FsDoc/library.html#setProperty-Context-map
    setProperty(context, {
                "entities" : someQuery,
                "propertyType" : PropertyType.APPEARANCE,
                "value" : color(1.0, 0.5, 0.2)
    @Jake_RosenfeldI believe @vikram_babu080is asking about changing a line colour not a part colour.
    Cheers,
    @owen_sparks
    D'oh!  Thanks :)
    Just following up on this question, has this been implemented yet? I am interested in changing the color of a line if have created using opFitSpline from a black line to a different colored line.
    Hi @vikram_babu080
    There is currently no way to change the color of an edge in Onshape (in FeatureScript or from the UI).  If you would like to see this functionality implemented please add an improvement request on the Improvement Requests section of this forum.
    Something that may be helpful in the meantime:
    https://cad.onshape.com/FsDoc/library.html#debug-Context-
    If you call `debug(context, edgeQuery)` in FeatureScript it will turn the edge red.  The red will only appear when the feature dialog for your feature is open though.  Once the user presses the green check mark, the red will go away and the edge will be black again.
