WHy does rib fail to generate when one end is the edge of a curve
I have tried to create a rib and if the end is coincident with the edge of a curve it fails to generate, and I would like to understand why. In the linked document I don't get why the rib through a sketch and extrusion works and the rib feature doesn't.
Any pointers?
https://cad.onshape.com/documents/1c3d44bf23c6372e72be8e42/w/f39f358e7c77dff1a16fc39e/e/e878ee492c01817c8bed6ec1
Any pointers?
or if the rib profile ends in line with the corner it again extrudes a rectangular profile to the main part (construction line is perpendicular to the rib profile and co-incident with the corner of the part):
It only fails if the rib profile line is co-incident.
I can see the logic for why it fails, I just don't see why the original design couldn't be generated as the extreme case of the either of those results?
