anybody know how to cut sweep this revolve along the path?
 mcconnell113
                    Member Posts: 74 ✭✭
mcconnell113
                    Member Posts: 74 ✭✭
             jakeramsley
                            Member, Moderator, Onshape Employees, Developers, csevp Posts: 668 jakeramsley
                            Member, Moderator, Onshape Employees, Developers, csevp Posts: 668 Currently no. I would probably do a sweep of the cross section then use the transform + copy part feature to position the revolve at the end caps followed by a subtraction. Currently no. I would probably do a sweep of the cross section then use the transform + copy part feature to position the revolve at the end caps followed by a subtraction.
 The end caps of the sweep would have an extra revolve'd area removed which could be done as a separate operation.Pete_Yodis said:@McConnell113 Onshape currently handles only swept cuts from 2d sketches and regions. For your example, I don't there would be a geometric difference between the capability in Onshape and a swept cut of a body.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
Saplingstore.com
Saplingstore.com
Saplingstore.com
Saplingstore.com
Saplingstore.com
Saplingstore.com
