Help with a Model and the Shell command
john_gentilin
john_gentilin Member Posts: 15 ✭
edited November 2017 in Community Support
With this model, I want to apply the shell command but I had the hardest time making it work. According to this post there was a mention about the smallest outside radius had to be bigger than the shell thickness. So I kept reducing the thickness till the shell command worked.
https://forum.onshape.com/discussion/7191/trying-to-shell-out-a-part
My question is, can someone tell me where my radius are too small, most of my revolves have huge radius's, maybe it's an intersection of two revolves.  I would like to have a shell thickness of 2-3mm, and not .3. Here is a link to my model.
https://cad.onshape.com/documents/46fa6561c3c0d839fb353ade/w/c9b9b354f1c329909efc014b/e/c676b3104fc0136db7a1726a
Thank you
-John
  • john_gentilin
    I made a revision named "Shell Thickness" if I happen to move on to other parts.
  • john_gentilin
    Andy, thank you for the quick response.  How did you produce that B&W curve plot ?   The back of the neck is not complete yet, I was just getting started with the shell to see how it would look then ran into problems. I still need to model the back of the head and make a real neck.
    Do you have any pointers to learn more about degenerate points/geometry ?  I think I understand your explanation, but need to do some more research.  I did notice that the "thicken" command was complaining about that point specifically but the error message just said it could not rebuild the geometry.
    Thanks again
    -John
