Offset subtracted Threads
I downloaded a model of a part with some large threads on it. I'm trying to make a mating 3D printed part that can screw into the threads. I'd like to subtract the threads from my part for 3D printing and offset them slightly so that when printed they aren't too tight. However, when I try to offset the threads (both inside the boolean and after I do the subtract) I'm unable to. Any advice on how to make that work?
This is the part I imported:
I'd like to try to make threads that fit into both the top and bottom inner threads on that part.
Here's the subtract I tried on the bottom threads:
When I tried offsetting in both the boolean and after it didn't work.
Thank you all in advance for the help!
Also, to ensure sealing, I would smooth the surface of the 3D printed part by exposing it to acetone vapor. This will create a better sealing surface and also make the threads slightly smaller.
https://cad.onshape.com/documents/a92da9dbcce4f30edcaafb9e/w/573739918210262dfe8f403a/e/059b8d5159706e1b7c69c7ea
Ok, here is my go - works just fine (using offset)
https://cad.onshape.com/documents/6561bd49e59dd3f06e7cfe1a/w/2e09664a13ec7e8aaefd1583/e/0fff9d8884c0ff712edff941
