lines
Just a quick question. is there a way to thicken a line in or on a sketch so when exported in a dxf file it would show up for a plasma or laser cutter to relive it, or is there some form of work around, ive read its on onshapes job to do, how do other people get around this little problem. thanks barry
Hans_Ole_Leirvik Member Posts: 82 PRO
Try to right click on a flat surface in the 3D model (not in a sketch) and select "Exports as DXF/DWG"5
