Variable name completion?
jmsaltzman
Member Posts: 20 ✭✭
in General
I'm curious about help filling in variable names: is there a "completion" feature?
For instance, if I have a variable named "hole_clearance," is there a way to type "#h" and have the rest filled in, or to pop up a list of variables starting with "h" if there's more than one?
No sure if there's an existing improvement request, if so you can vote on it to get it moved up the priority list, if not you can raise one.
Cheers Owen S
You can vote up this request and add your thoughts to the comments.
