I'm new in OnShape Script. I need to get ALL vertices in MESH DATA
I try to get some information from standard feature, but i've found only a single pick. It's possible to get all vertices to make Reverse Engineering functions?
var HkFHsuZZvqGABe_query;
HkFHsuZZvqGABe_query = makeQuery(id + "F6b3iaE6aysjsLh_0.merge.FwfB7UYxFAubFwQ.importOp", "IMPORT", EntityType.FACE, { "importTag" : 0.0 });
annotation { "Feature Name" : "Mesh point" }
cPoint(context, id + "FmkO3t4rtgA8ZBT", { "pointType" : PointType.MESH_POINT, "mesh" : qUnion([HkFHsuZZvqGABe_query]),
"x" : { 'value' : try(0.007071100175380707 * meter), 'expression' : "0.007071100175380707 m" }.value,
"y" : { 'value' : try(-0.009999999776482582 * meter), 'expression' : "-0.009999999776482582 m" }.value,
"z" : { 'value' : try(0.007071100175380707 * meter), 'expression' : "0.007071100175380707 m" }.value });
var WwWePlgJmkBLnb_query;
WwWePlgJmkBLnb_query = qCreatedBy(id + "FmkO3t4rtgA8ZBT", EntityType.VERTEX);
debug(context, WwWePlgJmkBLnb_query);
for (var vertex in evaluateQuery(context, WwWePlgJmkBLnb_query))
const vertexPoint = evVertexPoint(context, { "vertex" : vertex });
debug(context, vertexPoint);
Thank
Carlo
Thank
Carlo
kevin_o_toole_1 Onshape Employees, Developers, HDM Posts: 565
Hi and welcome to Onshape!
There's no direct way in FeatureScript to do what you're asking. Onshape has ways of referencing individual vertices, but no way to programmatically use all vertices in a full mesh.
What is your ultimate goal? If you just need the point data, you can obtain this information directly by converting to .obj or a similar format. If you need to move, stretch, or scale the data, you can use Onshape's transform tool and re-export as STL. If you need to do geometric work on every point, a BREP-based CAD system like Onshape is not the ideal way to work with this data — the functionality is (primarily) designed for high-precision, analytical surfaces, not faceted surfaces approximated with a huge number of points.
1
your answer is very clear.
I can tell you that i try to porting one C# dll that use new ideas to make reverse engineering conversion from mesh to analytic surfaces.
So no problem
So now we continue step by step and we try to put the first prototype in sharing with the community as soon as possible so everyone can see what we can do and also improve our work.
Sorry for my poor English and thank for the answer.
So no problem
So now we continue step by step and we try to put the first prototype in sharing with the community as soon as possible so everyonecan see what we can do and also improve our work.
Sorry for my poor english and thank for the answer.
Carlo
