Tracing a shape imported from png file
rex_hanson
Member Posts: 41 ✭✭
A friend of mine created a png file of a 2D shape outline using Inkscape. I'd like to use that shape in a sketch so I can extrude it. Is there a way to do that?
NeilCooke
Moderator, Onshape Employees Posts: 5,995
The profile must be shaded for it to extrude. One trick to find where the problem lies is to draw a line across your profile and move it around to see where the problem is. In this case the highlighted vertices do not touch. Also, for some reason, every entity is duplicated twice over the top of each other.
Also, rather than offset the sketch entities, extrude the profile solid then use the shell command to hollow it out.Senior Director, Technical Services, EMEA8
https://forum.onshape.com/discussion/comment/33693
I was hoping to have something that would allow me to simply select the edges. Better yet, select the middle and automatically grab the entire profile. Manually adding a bunch of points around the perimeter is tedious and error prone. There is the added problem that some of the edges are straight and some are curved. So putting a spline through them will have to be in a piecewise fashion in order to get the straight sections straight.
I also don't want you to wait around for the 'next' 3 weekly update only to be disappointed each time - our pro users have given us a long list of production-necessary requirements that we will be working on for a while and to be frank, this isn't on the list.
Have you tried looking at some of softwares that come with desktop engravers? These applications tend to be more along the lines of supporting the type of functionality that you are looking for (specifically turning pictures into toolpath with z height grading)
At the hobby-level, Fusion360 can read SVG files and generate an outline.
At the pro-level, Mastercam can do what you're looking for -
There are probably others in both categories
I hope this helps you.
Can you post the URL of your document with the DXF in it here? It'll be easier to help if we can see what's going on.
https://cad.onshape.com/documents/b93bcfee7b328fad0af64039/w/39747b556ec570dd85c6b8a5/e/d43dad017ab9001e8eed5ea8
I'm working in the 'New W' tab.
Was able to open it in Google Chrome long enough to save a copy though. Just thought you should know.
