Imported STL-Mesh to solid Part (?)
Kai_himselfKai_himself Member Posts: 45 ✭✭
Hey,
im straight new to OnShape :). It is a very cool CAD Platform !
Here my first problem, i imported a *.stl File to onshape. Onshape shows only Meshes but no Parts. Even in the Assembly Studio i cant choose the Mesh to import it.
How can i creat a solid (?) Element from a imported Mesh ?
Thank you for your support.
Have a nice weekend
Kai
    edited November 2017
    So stl file format is just a cloud of points so you're going to need to do one of two things:-
    (a) Reverse engineer the part. Each point in the stl can be projected, so if it's a simple part this is doable.
    (b) Find the part in a different format. OS will accept just about anything, but I'd try for parasolid or step file.
  • Kai_himselfKai_himself Member Posts: 45 ✭✭
    Hey Owen,
    thank you for your answer.
    I try to reverse engineer the part.
    Bye
    Kai
    Sure thing, shout if you get stuck.
    OwS
  • brad_phelanbrad_phelan Member Posts: 90 ✭✭
    Space claim has support for reverse engineering STL to CAD.
    http://www.spaceclaim.com/en/Solutions/ReverseEngineering.aspx
