Creat a T-piece out of two arc's
Kai_himself
Member Posts: 43 ✭✭
Hello Forum,
i need your help again.
Im trying to make a t-piece out of two arc's. I created the arc's with 3-Pouint-Arc and feeding. Now i would like to cut out the overlap in the middel of the arc's. I try the boolean operator, but the right solution is missing. I got only wrong results.
On the first picture you see the double arc.
On the following pictures you see the results of the boolean operator.
How i cut the middle out of the arc's ?
Here ist the link to the projekt: https://cad.onshape.com/documents/9a8c0aecf6767e09f530f535/w/005aa049af7ccc68815152aa/e/5d4e771f31850bc0087467a9
Greetz Kai
Greetz Kai
Optionsdick_van_der_vaart Member Posts: 51 PRO
Is this what your looking for,
https://cad.onshape.com/documents/13bcba9d99678dba4a9cc638/w/3604ec8b5bfd892fb8fc567b/e/e326273ac62272770f48623c
Grussen Dick
Is this the end result you are looking for? I constructed the model using symmetry so you can visualize it easier.
https://cad.onshape.com/documents/406a6d81ebcc7282f27a3b16/w/ec8e6db5686e2d54faf089fe/e/f71b9e4c5d3f5a3a57c38825
The document is failing to load because it is not shared in the public space. Is it possible for you to share it to public? Thank you in advance!
thank you for your answers, sorry i was not at home at the weekend.
All documents are online for me . At first i tried the way from @dick_van_der_vaart, but i do not work. I dont know which areas or bodys should select on shell1 ....
PS: Now i use the cutview
Thank you for your help !
