Is this a bug or do I something wrong ?
franz_balleis127franz_balleis127 Member Posts: 23 ✭✭
edited December 2017 in Community Support
Hi,
im not sure igf i make something wrong or this is a bug but I'll begin to explain.
!) I have created a drawing which was then mirrored. See below
In this form I would like to insert 3 oblique cutouts at 10 ° inclination. For this I have created new layer and built the following auxiliary construction to then remove the desired material by rotation and extrution.
So far so good. If I now try to select the 3 objects for extruding, this only works for the two outer objects ????
I can not choose the middle one, why? Maybe that has something to do with the mirrored base object? I would be very happy about a help or an answer.
    Please will you post a link to your document, then I'm sure someone will help.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,988 image
    Please post a link to your document so we can see what’s going on.
  • John_P_DesiletsJohn_P_Desilets Onshape Employees, csevp Posts: 273 image
     franz_balleis127
    The revolved part produces a nonplanar face and that is why it was not able to be used for the extrude cut. I corrected this by making the revolve axis perpendicular to the sketched line to be revolved. Hope this helps!
    Corrected
    Hi.
    I believe your problem is here:-
    The middle part is not flat because that angle is not 90 deg, therefore it isn't a valid input for an extrude.
    Always make sure your sketch lines and points turn black, to show they're fully constrained.
    Hope that helps,
    @John_P_Desilets
    Damn, I should have hit the refresh button in the forum before answering the post. :'(  At least we agree on the issue.
    O.S.
  • franz_balleis127franz_balleis127 Member Posts: 23 ✭✭
    Hi Owen,
    many thx for the help. Often it's just a small thing that lacks or does not fit, But as a 3-D beginner, such things can lead to big stumbling blocks.
    Now it'ok
    Franz
    Great to hear, nice project by the way.
    Cheers,
    Maybe I have some more questions on this project who knows :)
