Is this a bug or do I something wrong ?
franz_balleis127
Member Posts: 23 ✭✭
Hi,
im not sure igf i make something wrong or this is a bug but I'll begin to explain.
!) I have created a drawing which was then mirrored. See below
In this form I would like to insert 3 oblique cutouts at 10 ° inclination. For this I have created new layer and built the following auxiliary construction to then remove the desired material by rotation and extrution.
So far so good. If I now try to select the 3 objects for extruding, this only works for the two outer objects ????
I can not choose the middle one, why? Maybe that has something to do with the mirrored base object? I would be very happy about a help or an answer.
Please will you post a link to your document, then I'm sure someone will help.
Owen S.
HWM-Water Ltd0 -
Please post a link to your document so we can see what’s going on.Senior Director, Technical Services, EMEA0
Hope sombody can help.. better explain to me what I did wrong
https://cad.onshape.com/documents/05d1152c062c7083da72e175/w/a1df7b0c54724f5482a22635/e/a4a3980b24a8dc28b83eafd6
franz_balleis127
The revolved part produces a nonplanar face and that is why it was not able to be used for the extrude cut. I corrected this by making the revolve axis perpendicular to the sketched line to be revolved. Hope this helps!
Corrected
1 -
Hi.
I believe your problem is here:-
The middle part is not flat because that angle is not 90 deg, therefore it isn't a valid input for an extrude.
Always make sure your sketch lines and points turn black, to show they're fully constrained.
Hope that helps,
Owen S.
HWM-Water Ltd1 -
@John_P_Desilets
Damn, I should have hit the refresh button in the forum before answering the post. :'( At least we agree on the issue.
O.S.
HWM-Water Ltd0 -
Hi Owen,
many thx for the help. Often it's just a small thing that lacks or does not fit, But as a 3-D beginner, such things can lead to big stumbling blocks.
Now it'ok
Franz
Great to hear, nice project by the way.
Cheers,
Owen S.
HWM-Water Ltd1 -
Maybe I have some more questions on this project who knows
1
