How to create plugins for Onshape?
Thank you for Onshape! This program is great and very impressing. It is hard to imagine that so small team in so short time can implement so cool system.
Could you tell me, where I can read about possibility of implementation of my own plugins for Onshape? (usually I create many small tools for automatization of simple operations; but now it is not clear, how to do it in Onshape). I expect it is important question for many beta-testers, but I can't find any information about it on this forum.
Thank you.
Thank you.
Optionsstephen_lewin_berlin Onshape Employees Posts: 20We haven't published our API yet, but it is coming... I'm interested in what kind of plugins you have in mind. Feel free to answer here, or message me privately if you prefer.
Steve
Onshape Partner & API Lead6 -
Optionsstephen_lewin_berlin Onshape Employees Posts: 20The first release of our API will be more focused on enabling partners to deliver applications that work with or integrate into Onshape through mechanisms such as REST calls. Supporting user-defined plugins is definitely of interest as well, but we aren't prepared to discuss how that will be done, and in fact, I expect that there will be more than one way to create plugins. Yes, we will support ways to share such plug-ins eventually.1
Steve
Is there any date or timeframe set for an API public release?
Saplingstore.com
- I have a rough tesselation of surface (few hungreds of triangles),
- I need to replace each triangle (with vertices v1, v2, v3) of special type by three new triangles.
- I.e. I need to calculate coordinates of new vertex v4, delete existent triangle, and add three new triangles: (v1, v2, v4), (v2, v3, v4), (v3, v1, v4),
- also I need to check special conditions of replaced triangle (i.e. do I need to replace it or can I keep it).
Now I can do such things with the most of off-line CADs. I suspect that many of CAD users sometimes need such special simple operations. So I was very surprised, that there are no many questions about plugins for Onshape on this forum.
I only need to know, how do you plan to allow users to create plugins. Will it be on Javascript (it seems logical for web)? Will it be executible in browser or in cloud? Will it be possible to share my plugin for other Onshape users (like I can share any model)?
For our applications, it could be:
- something such as high-level design tool following a standard pattern (e.g. automatically generate design to assemble 2 parts).
- generate URDF from a robot assembly,
A useful example of a plugin would be constructing frames with predefined profile-sketches. (parametric defined sketches)
For example round, square or rectangular predefined profiles(sketches) that are (automatically)extruded to tube-shapes.
In this way we could construct a tube-frame structure very easy, thus without making for each tube a profile sketch and extrude the sketches to create a frame.
Then we could make special joint types(predefined) to connect the tube ends.
Maybe some kind of feature detection mechanism to detect certain features(in this case if solid is a tube shape)
Best regards,
Guido
