Is it possible to Use(Project) the tangent lines of this cylinder, only edges seem possible
micdomin
Member Posts: 16 PRO
paul_chastell
Onshape Employees Posts: 126
@dominique_michel, is the silhouette available if you select the Use command first and then hover over the face? See https://cad.onshape.com/help/#sketch-tools-use.htm?Highlight=silhouette. In particular you cannot add silhouettes by selecting the face first and then using, you need to use the post-select method. If you can't add the silhouette in any way with use then I would suggest submitting a ticket to support so they can look into it.Paul Chastell
TVP, Onshape R&D5 -
Tony_C_
Member Posts: 280 PRO
I've noticed this too. There are some cases were you can select something then hit "use" and it works, then other times it fails and you need to hit "use" first, then select the item.paul_chastell said:@dominique_michel, is the silhouette available if you select the Use command first and then hover over the face? See https://cad.onshape.com/help/#sketch-tools-use.htm?Highlight=silhouette. In particular you cannot add silhouettes by selecting the face first and then using, you need to use the post-select method. If you can't add the silhouette in any way with use then I would suggest submitting a ticket to support so they can look into it.5
TVP, Onshape R&D
