maybe a noob question
juvykjuvyk Member Posts: 8
hello, i'm use onshape for 1 month and now i'm stuck..
Anyone know how to joint this two point ?
Ps:I'm using sketch for the curving part  and bevel for the top .
thank you
  • mahirmahir Member, Developers Posts: 1,320 ✭✭✭✭✭
    edited December 2017
    There are many ways to blend away that sharp point. What kind of transition are you looking for? Do you want that whole corner to be smooth? If so, add a fillet to the lower rounded corner edge, preferrably the same size (and feature) as the existing fillet. Then, you can add another fillet around the border to make it even smoother.
