Is it possible to Use(Project) the tangent lines of this cylinder, only edges seem possible
micdomin
Member Posts: 16 PRO
paul_chastell Onshape Employees Posts: 124@dominique_michel, is the silhouette available if you select the Use command first and then hover over the face? See https://cad.onshape.com/help/#sketch-tools-use.htm?Highlight=silhouette. In particular you cannot add silhouettes by selecting the face first and then using, you need to use the post-select method. If you can't add the silhouette in any way with use then I would suggest submitting a ticket to support so they can look into it.Paul Chastell
TVP, Onshape R&D5 -
Tony_C_ Member Posts: 272 PROpaul_chastell said:@dominique_michel, is the silhouette available if you select the Use command first and then hover over the face? See https://cad.onshape.com/help/#sketch-tools-use.htm?Highlight=silhouette. In particular you cannot add silhouettes by selecting the face first and then using, you need to use the post-select method. If you can't add the silhouette in any way with use then I would suggest submitting a ticket to support so they can look into it.5
TVP, Onshape R&D
