Selecting Derived Sketch
papawo
Member, Developers Posts: 206 PRO
can somebody explain me , how to achieved this. I have sample code that I can use but I want to know the basic.
Example document:
https://cad.onshape.com/documents/de90c930e40cf8bcf4a5fb07/w/754c83eb6f9cb3ab6b29f73b/e/6437c056f266e6142585dc0b
why do it needs to have export before function?
why is the debug shows resolves bodies?
When using this in your code, you should remove the debug() line of code, and use the variable "entities" wherever you would have previously used "definition.profile". If "entities" is not a good variable name for your feature, you can replace it with a better one. After renaming, the old definition.profile input can be entirely removed from the precondition.
In short: Bodies can be 3D, 2D, 1D, even 0D. Sketches create both 1D wire bodies (sketch edges) and 2D sheet bodies (sketch regions).
