How do I create a two slant kind of drain?
meghan_frederick
Member Posts: 8 EDU
I am trying to create a drain type of thing, where I want to put water down a container and it moves to the center using two slants. I can't seem to get both slants, I can only figure out how to do the first one.
Tony_C_
Member Posts: 280 PRO
Are you wanting the inside to slope towards the hole?
https://cad.onshape.com/documents/2afb0590382985ee1e45bc55/w/1f6e968f72456d69ab021896/e/297674fb4f3b43f56addf28a
5
We need to have a bit more idea of what it should look like. Could you do a sketch or share an Onshape doc? Or more description...
