How do you add a radius curve to a bent wire?
MetroMetro Member Posts: 17 ✭✭
Hi there,
I have apart of profiled wire with two 90 deg bends. On the top profile I did a simple sweep that runs from down the y-axis makes a 90deg turn to the left than another turn left to continue down the y-axis  I would like the wire to also have a curved radius of 300- 400mm (12-16") the radius curve running along the y-axis and rising up the z-axis of the right plane. Anyone know how to achieve this?
Here is a link to the part if that helps
Thank you for any advice
-Metro
https://cad.onshape.com/documents/689fc63eca46ed4287e4366e/w/a8d76ebe928e96b0e85f258e/e/635bd193e0a6679801c33e33
  • MetroMetro Member Posts: 17 ✭✭
    Aaaaha! Thank you Mahir...I thought it was the Projected curve but I couldn't seem to crack it. Thank you very much!
