How do I place a grid layout in onshape?
PIETER
PIETER Member Posts: 1
I'm currently designing eyewear, problem is that i can't get any of my dimensions in, I want to also curve the shape of the glasses to match the face of the client. Do I add extra plane's or do I draw in the grid manually via the sketch tool?
  • brucebartlett
    brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
    No Grid in the sketcher. Also no way to get hand sketches or vector based 2d geometry into the sketcher. You could translate a 3d models in to a  new part studio and project lines from this using the "use" feature but no good if starting from scratch. I'd manual draw a grid or a set of points, followed by lines and arcs or splines. You may need to add planes to get the 3d shape but I tend to avoid having too many planes and work off sketches.  image
