advice for complex chamfer (Resolved)
Hello ,
Anyone have advice for what I should use for this complex chamfer ? I need to join my chamfer to one point but with curve (check the picture with red line). I try sweep or loft but maybe i don't use the good method.. Thank you , sorry for my bad english.
BOOM!
https://cad.onshape.com/documents/b89c7b3da7f69872955aa8b7/w/881566f8f4ba92caaee21f8e/e/a327d9a2addb740b33600605
Clever use of variable fillet! And fill surface is powerful...
With all the surfacing improvements, I am getting good results with some of my problem type jobs
Unlike with fill surface, the resulting surfaces are planes and cones and they're at a 45 degree angle to vertical (see draft analysis).
