Troubleshoot the message "did not generate properly; some references missing"
famadorianfamadorian Member Posts: 390 ✭✭✭
Everything was fine and then it lights up red and gives the message that something didn't generate properly. Are there some color indicators or messages that I can look at to see what it thinks the problem is?
Model is here:
https://cad.onshape.com/documents/a7bd8defc7e4f542b0895756/w/d66f27535992b0818eb904a2/e/31a3d8e6f6e6dbd92e175af5
    michael_watsonmichael_watson Member Posts: 15 ✭✭
    Was unable to make a copy of this one, but the one posted here allowed me to make a copy of the project so I could open the bolt profile sketch. If you open the bolt profile sketch and have the 'show overdefined' selected, it will show a midpoint constraint as a problem. Delete that constraint and it will successfully generate.
