How do I chamfer the rest of my drawing?
I have chamfered most of the sides I want to in my drawing however two of the sides won't chamfer. I want a .3in long distance chamfer with a 30 degree angle. How would I get the other two sides to chamfer?
https://cad.onshape.com/documents/a0166c3d395bc3e4a3a2bc9f/w/5f0924243cf8fda4d2e8b5ac/e/943c69078ba8012e18028440
mahir Member, Developers Posts: 1,315 ✭✭✭✭✭
Try adding the chamfer AFTER the fillet. The chamfer should propogate along the tangent edges. Here's one example of how to do this. I also slightly changed the fillet radius and added that center cut after the fact so the chamfer would be applied more smoothly.
https://cad.onshape.com/documents/6f23b7b818dc635052a715f2/w/bd0a08c448bef6f128bff529/e/2db8b0e3c89f7b4cb00ffc63
2
