Visual Pipeline
in General
Are there any plans for some sort of visual pipeline for constructing in onshape? Using nodes, inputs and modules to somehow do visual programming?
projektowanieproduktow.wordpress.com
That said, Onshape DOES give you the ability to create your own Custom Features using the same feature development tools that our developers use. This is unique in the industry and enables you to both learn from our source code (we open-sourced all of our feature source code) as well as create features and productivity tool that are 'first class citizens' (meaning that they will always regenerate and are treated just like the built in ones - for example, the inputs can be configured).
This capability has been met with resounding enthusiasm and the creation of some amazing features - check it out!
www.onshape.com/customfeatures (there is also a link there to our source code).
