I can't get the polygon sketch to work properly.
I'm sorry if this has already been asked or if it's a stupid question but i can't find an answer to it. When I try to put multiple 6 sided polygons on a sketch, everything turns red and i get a message saying the sketch couldn't be solved. Sometimes when i undo it and try it again it works, but now it won't work at all, what am I doing wrong?
If you posted a link to a doc with two sketches (one just before the problem appears and one just after), i am sure we could figure it out for you.
No, there is no limitation on the number of polygons you may have in a sketch.
