Trying to get these dimensions into the part
mark_cunninghammark_cunningham Member Posts: 78 ✭✭
https://cad.onshape.com/documents/f0add174c6d6e79389e638ba/w/6614903f3758ece2a31374db/e/52ce347a9b5ae2e33248acd2
So i'm still very new at this and i'm trying to get these dimensions into the front/face of this part. from the radius back needs to be solid with the secondary line shelved over over hung to accept a pin head with a shaft. the pin head will stop under the shelf. the tapered lines gradually  tighten up on the pin head until it stops when sliding the part down the channel. any help is good help! Thanks so much!
    @mark_cunningham. This is not a drawing question (the general community support section would be better)
    That said, we want to help - perhaps it would be helpful if you could post of sketch of the geometry you are trying to build?
    If the forum could see what you're trying to build, they could do it for you lickety split! :)
    Philip Thomas - Onshape
