Configuring Configure Features
tim_wheeler
Member Posts: 21 PRO
Kudos to the team for the configuration feature. Really powerful.
Now, a question:
Is it possible to configure configuration features.
In other words, can you remove configuration options based on other configuration choices/inputs.
In the cylinder part studio used in the webcast, for instance. In smaller bores, some features might not be possible because of real estate. Is it possible to limit, or gray out some list selections based upon the #Bore selection. For instance, in a small bore cylinder, the port sizes available might be the two smallest port sizes, (e.g.,1/8 NPT & 1/4" NPT) while as the bore grows, other port sizes would become available, (e.g.,1/4" & 3/8") while some would be too small to be useable (e.g. 1/8" NPT too small to power 12" bore cylinder).
Is it possible to limit the scope of table selections based upon the value of previous inputs?
Please advise.
Now, a question:
Please advise.
I know it sounds convoluted, so I made an example using a simple washer model. In the example you can select from 3 different ID sizes. Selecting the ID also changes what the array elements are for #OD. Then, selecting OD size changes #ODSize to either 0,1, or 2. Now the OD size for Sml/Med/Lrg will change depending on what you've selected for ID.
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/bff7c0eb0103e281d089cf51
I think the answer is dependent configuration inputs, or sub-inputs. that can be validated by the main table.
I keep thinking there might be a work around with variables or if-then statements, such as the one in the introduction video.
A secondary table that allows you to suppress/unsuppress of configuration options would do the trick in my mind, but I have no idea whether that can be done given the current architecture.
Ultimately it will take some type of work-around to make this work. The lack of NPT hole options mean the whole thing is in beta in the mean-time..
I appreciate your input.
