Add "Offset From Surface" to Extrude
Mark_Matthews
Member Posts: 25 ✭✭✭
I would like to see "Offset from Surface" in the end conditions list in the Extrude feature. This would maintain a wall thickness when making a cut, or a clearance from a surface making a protrusion.
MBartlett21
Member, OS Professional, Developers Posts: 2,063 ✭✭✭✭✭
@Mark_Matthews
You can choose "up to face" in the drop-down menu in the extrude feature, then tick the box labelled "offset distance".
Does this solve your problem?7
