NEED SOME EXPLANATION
papawopapawo Member, Developers Posts: 206 PRO
    @Nancy
    See this part of the documentation:
    https://cad.onshape.com/FsDoc/library.html#defineFeature-function-map
    Those defaults are used when the feature is called from FeatureScript.  When your feature is called from the UI, the UI will set the value of input parameters before those defaults are applied.  What type of parameter are you trying to set a default for?
  • papawopapawo Member, Developers Posts: 206 PRO
    edited January 2018
    Im trying to understand the code. no parameter in particular.
    @Nancy
    If you want to set UI defaults, you can use a BoundSpec for ValueWithUnits types:
    https://cad.onshape.com/FsDoc/library.html#module-valueBounds.fs
    or you can do the following for strings, booleans, and enums:
    https://forum.onshape.com/discussion/8257/in-precondition-how-do-i-set-a-default-value-for-a-boolean#latest
    The set of defaults that you point out exists so that if someone were to call your feature like this:
    extrudedMember(context, id + "em1", {});
    Their blank map would be filled with the set of defaults that you've provided.  If they provide some arguments, only the ones they haven't specified will be filled in from the defaults map.  Generally, unless you expect that other people will be calling your feature from inside FeatureScript (instead of using it from their toolbar), there is no need to define defaults in the place you are wondering about.
    @Nancy
    It may be easier to explain if you post screenshots of what 'isBiDirectionalSolidExtrudeDef' and 'EXTRUDE_DEFAULTS_3' actually are.  If any of the parameters you are trying to change using EXTRUDE_DEFAULTS_3 appear in isBidirectionalSolidExtrudeDef(...) the default will not apply because the parameter is being set by the UI, not the defaults map.
    edited January 2018
    can i share the doc with you?
    so any parameters that is in isBidirectionalSolidExtrudeDef will overwrite what is in EXTRUDE_DEFAULTS_3?
    thanks! its clearer now.
