Is it possible to make an s shape hole through a solid object?
taylor_vadon
Member Posts: 3 ✭
in General
Hey all, newbie here. Im working on a project where I want to have an s shaped hole in a solid object. Im having a rough time with this and if anyone has some good ideas as how to do this it would be greatly appreciated, Im running out of hair to pull out! Thanks
You can also draw an S-shape by using Lines and Arcs in a sketch or you can also draw the shape using splines in a sketch.
You may also be asking for what is called a "sweep" I made and 'S' shaped sweep with an 'S' profile because why not
Check out this document I made for you:
https://cad.onshape.com/documents/cefc96aed0b80a727061e3ef/w/9fbcf415b2cd55745e3b47d9/e/eea698102c84feff8440e850
https://www.onshape.com/videos/sweep
https://www.onshape.com/videos/sketching-basics-onshape
Onshape allows you to create text in sketches:
https://cad.onshape.com/help/Content/text-rectangle.htm
It may be helpful to check out our learning center! There are a number of beginner courses in Onshape Fundamentals: CAD that will help you understand the basics of the system.
https://learn.onshape.com/
Happy CADding!
