Assembly
dan_schwartz
Member Posts: 16 ✭✭
Hello
Can I add planes to assembly?
What is the way to start from layout?
D
D
Onshape uses Mate Connectors (local coordinate systems) and high level mates.
To orient parts in an assembly you can either;
1) Use the manipulator triad - this includes 'align with z', 'anti align with z' and 'move to origin, OR
2) Mate to the origin (both implicit and explicit mate connectors can be generated at the origin).
That should get you started.
Are there any specific scenarios that you are struggling with?
https://learn.onshape.com/courses/section-views-of-cylindrical-parts
There are a bunch of awesome technical papers here.
That said, the work arounds are to add surfaces as you mentioned, or you can add sketches to the assembly. Constraining the sketches can be a bit of a pain, but that's also possible. You can always drop them in at their position from the part studio and then group them to keep them from floating around. One advantage of a sketch in the assembly is that it doesn't clutter up the BOM.
