How do you increase the size of entire sketch all at one time?
james_whittington
Member Posts: 12 ✭
in General
How do you increase the size of entire sketch all at one time? I understand that you can increase each individual part and accomplish this, however I was wondering if it is possible to select the entire part at one time, then increase the size of the part by a percent or value (1.5x or 2x) in size?
Hello James! The first dimension you create will scale the entire sketch.
For a part you can scale uniformly using the transform, scale uniformly option.
Are you working with imported data by chance?
