Is it possible somehow to Scale with a variable ?
oriane_kassisoriane_kassis Member Posts: 2 ✭✭
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,255 image
    I suspect the problem is that your variable is a length.  It either needs to be a real number or you need to divide it by a length to get a number.  Basically, the request "I want this bigger by a factor of 2 inches" doesn't make sense.
