How to export coordinates for hinged assembly?
Hi all,
I've got an assembly of 2 doors, linked by a mechanism in Onshape. As one door opens, the other responds, with one door counterbalancing the other.
I'm trying to figure out the forces in the links between the doors (chains in reality), to help optimise the geometry and so maintain equilibrium across as wide a range of movement as possible.
I've already got a simplified Excel based trigonometric model, but as the system is somewhat non-linear, the simplifications are adding too much error.
I want Onshape to open one door by angular increments, and export the corresponding angle (or X-Y coordinates of a point) on the other door, in a format which Excel can import. I can then develop this to plot a graph of chain load vs angular opening.
Does anyone have suggestions of how to do this?
Hopefully someone with some talent will be along soon
Check out the simulation partners - https://appstore.onshape.com/apps/Simulation
It looks like SimWise4D works with rigid body kinematics.
Good luck!
Many thanks all for your comments.
https://cad.onshape.com/documents/2e01af46ce2cd5b90ee41156/w/82761270dd57ac2be5d84860/e/274c362e3eeb03f14eaa43c1
the advantage is that in some cases you can visually see if the kinematic dependency is (or is not) good enough to suit you purpouses and iterate faster, since it is fully integrated in the part studio build process
