geneva cam assembly - intermittent relation
Josh_20
Member Posts: 2 ✭✭
Hello all,
Is there a way to make an intermittent relation to allow a Geneva Cam mechanism to work ?
Public Geneva Cam Document
Optionsphilip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381@Josh_20 - No, Onshape does not currently support intermittent contacts.
That said, there are solution partner apps that might be what you're looking for.
Check out Simwise4D in the simulation section of the app store.Philip Thomas - Onshape5
Finally - the guy that wrote the code (Bo) has a Phd in '3D kinematics' and is rolling his eyes at me!
Btw, OS's "add" functionality with surface part patterns needs some work. Surfaces that should merge just fine don't merge. The only way I could make the above surface one piece was by patterning the path and creating a single sweep. I should have been able to sweep 1/12 of the whole and create the rest with 2 circular patterns. But doing that results in 12 separate surfaces.
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/fc18786802f2ffec50ebb4a3
I made the slots larger than the pin, because the tangent mate was having trouble when the slot was the exact size to fit the pin. There's still more than 1 solution to the tangent mate, so it sometimes won't give the result you want.
