mate plane to part edge in assembly
dave_banks
Member Posts: 3 ✭
I find the mates to be somewhat difficult to use. Not straight forward like Solid Works or Inventor. I cannot figure out how to mate the edge of a tilted part to the face of another part. I have a small base plate, sitting on top of it are 2 pc's of flat bar stock in a "v" 90 degree shape (this will be a weldment) I need the center of the V in the middle of the base plate. I have the v configuration mounted on the base plate but I cannot get the V centered (constrained) on the base plate. How can I do this?
Thanks
Dave
Thanks
Dave
mahir
Member, Developers Posts: 1,319 ✭✭✭✭✭
I agree, it's not always intuitive. Yes, you can offset. The control is in the mate connectors. If you wanted the V to be off-center, you would edit the baseplate's mate connector to move it along it's X/Y axes (Z is always the primary axis for a mate connector). If your V parts have a different shape, then the mate connector would just need to be adjusted accordingly. As mentioned before, mate connectors are just local XYZ coordinate systems that you can place on a part in whatever location/orientation gets you the desired result.
I haven't looked at it myself, but here's a link to an assembly tutorial that touches on mating.
https://learn.onshape.com/courses/fundamentals-onshape-assemblies
5
Is there a tutorial that shows how to use each mate in more detail? If for instance, you wanted to have this V offset from the center, I assume this can be done. If your V parts are square ended (to allow for welding) how would you mate them?
OnShape constraining system is horrible, it must be fixed. I'm afraid it will take an eternity due to the shit framework they started years ago.
It is a pain in the ass if you use any other angle than perpendicular, and you'll never find what you really did to somehow miraculously make it work, and it will take all your hair.
