Centering shapes in drawings, What tool should i use?
tom_scotttom_scott Member Posts: 4
Hi, i'm fairly new to Onshape. Im after a simple way to center the middle rectangle - (width wise) within the larger rectangle. What tool should i use and how?
Thanks in advance.
  • tom_scotttom_scott Member Posts: 4
    Thanks again Michael!
  • joshua_samsjoshua_sams Member Posts: 28 PRO
    hi all
    (I know this thread is old but it very much describes the problem I am having right now)
    back when using solidworks I used to be able to select the midpoint of a line in a sketch and then also select a midpoint of a previous sketch/feature then constrain them vertically or horizontal.
    very powerful feature meaning they would stay in the middle no matter if I changed dimensions in the previous feature or the next sketch making revisions much neater and quicker
    using a construction line or constraints with a  centre rectangle works but only for rectangles. I often do sketches where I want just one line constrained that way
    is there any way to do this in Onshape?
  • wayne_sauderwayne_sauder Member, csevp Posts: 639 PRO
    edited August 2020
     If I understand your question correctly I would use a center point rectangle and constrain the center to the midpoint of a line in your other rectangle. Looked at your post again, you can put points(using the point tool) on center points of lines and contain only that point. I use that trick a fair bit.
