How to combine parts
Hello, apologies if this is a dumb question but as a newbie trying to get my head around Oneshape.
I have a simple extruded rectangle in parts studio 1. In parts studio 2 I have an extruded square. What is the correct procedure to "bring these parts together" as one ? I want to put the rectangle of PS1 on top of the square in PS2. Im thinking I should create an assembly but I thought assemblies were only intended when you wish to use physics etc. Thanks for reading.
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
Hi @MrMad1966 ,
To bring a part from one part studio into another you can use the "Derived" feature:
https://cad.onshape.com/help/Content/derived.htm
Really though, you should just create both blocks in the same part studio rather than using two separate studios.
https://learn.onshape.com/courses/fundamentals-multi-part-part-studios
https://learn.onshape.com/collections/onshape-fundamentals-cad
Jake Rosenfeld - Modeling Team5
