CLEARANCE FITS
What would be a recommended approach to dimensioning holes and pins in a model for clearance fits?
I need a more efficient way.
To date my way around this has been to use the same sketch for both hole and pin then in the drawings use +/+ tolerance for the hole and -/- tolerance for the pin.
However, this requires me to remember what the fit is supposed to be and when there are a lot of parts in a design this is hard to keep track of.
Takes me back to the days of drawing on paper.
If you are asking about model - a good way is: in part studio model one pin, Boolean subtract that with clearance offset to make one hole, and pattern faces for the remainder of holes. Or if the locations are more random, first transform copy the pin to locations before Boolean (see the third hole from bottom left) Then in assembly tab, mate one pin and replicate the rest. It is best practice to model one of each part and then 'instance' any duplicates in the assembly. Makes it easy to change and less 'overhead' (size of document).
See this example document.
What would be a recommended approach to dimensioning holes and pins in a model for a clearance fit between the two?
Good answer. Thanks.
Do you also model the hole and pin from separate sketches so the maximum material of each are not equal?
gerry
