Aline lines (selection) within a sketch
tgunrtgunr Member Posts: 45 ✭✭
If I have two rectangles in a sketch how does one align the left (or right or top or bottom) such that both left sides are aligned?
BTW, searching for this using the search function with tags "align" "alignment" resulted in two tesults neither of which ask this question
  • tgunrtgunr Member Posts: 45 ✭✭
    I just discovered that, however the problem with that is the rest of the rectangle have to be constrained correctly.
  • annie_nielsonannie_nielson Member Posts: 2
    make a dimension between them and then set it to zero?
