Configuring Part Property problem (Now FIXED)
Member, Developers Posts: 2,660 PRO
edited March 2018 in Using Onshape
Hi folks, I wonder if you can help?
I have a pipe that has two configuration inputs. (Length and colour.)
I can configure the appearance just fine but the configuration takes into account the length and colour options.
The length isn't relevant, so this method fails if the length is set to anything other than the default.
I don't seem to be able to delete the length column from the properties config.
What am I doing wrong?
Thanks for your time.
Cheers,
  • Onshape Employees, Developers, HDM Posts: 1,230
    For configuring properties, you currently have to specify all configuration inputs, so you can't delete a configuration input column from the table.  We're working on it.
    The only way you can currently set a color based on one configuration input is by writing a custom feature.  Here's one I whipped together: https://cad.onshape.com/documents/d290e9ee2e626a7b649b4927/w/194d18396c5bc98706ec2624/e/7b2aa285ed0349bc1a9fe1d7 -- you can configure the color parameters.
  • Member, Developers Posts: 2,660 PRO
    Wow, quick response, info on future enhancements and an immediate workaround.  This is why we love you guys.
    Thanks Illya.
    Cheers,
    Hello again.
    Works like a charm, thanks again :+1:
    Cheers,
  • Member, Developers Posts: 446 PRO
    Nice Feature Script! But it only works with parts that have never been assigned an appearance, so only "new" parts.
    Is there a workaround to overwrite/reset the appearance?
    Not yet, but we have plans for resetting properties so they can be controlled by FS.
    Sounds very good!
    I also adjusted you FS a little bit, now I can use integer RGB values (0...255)
    And you can set a material name and density :)
    <div>FeatureScript 765;
    import(path : "onshape/std/geometry.fs", version : "765.0");
    annotation { "Feature Type Name" : "Set Color" }
    export const setColor = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            annotation { "Name" : "Bodies", "Filter" : EntityType.BODY }
            definition.bodies is Query;
            annotation { "Name" : "Red" }
            isInteger(definition.red, { (unitless) : [0, 128, 255] } as IntegerBoundSpec);
            annotation { "Name" : "Green" }
            isInteger(definition.green, { (unitless) : [0, 128, 255] } as IntegerBoundSpec);
            annotation { "Name" : "Blue" }
            isInteger(definition.blue, { (unitless) : [0, 128, 255] } as IntegerBoundSpec);
            annotation { "Name" : "Alpha" }
            isReal(definition.alpha, { (unitless) : [0.0, 1, 1] } as RealBoundSpec);
            annotation { "Name" : "Material Name" }
            definition.myMaterialName is string;
            annotation { "Name" : "Material Density" }
            isReal(definition.myMaterialDensity, { (unitless) : [0.0, 1, 25] } as RealBoundSpec);
            setProperty(context, {
                        "entities" : definition.bodies,
                        "propertyType" : PropertyType.APPEARANCE,
                        "value" : color(definition.red / 255., definition.green / 255., definition.blue / 255., definition.alpha)
                        "propertyType" : PropertyType.MATERIAL,
                        "value" : material(definition.myMaterialName, definition.myMaterialDensity * gram / centimeter ^ 3)
    </div><div><br></div>
    Very Nice.
  • Member, OS Professional, Developers Posts: 2,055 ✭✭✭✭✭
    edited March 2018
    When will this be available?
    @ilya_baran
    Sounds very good!
        precondition
    @ilya_baran
    Maybe you could merge this change into yours?
  • Member Posts: 17 EDU
    Is there an improvement request tied to this? Looking forward to this update. I'd like to make my part properties not tied to a configuration variable.
  • Member Posts: 8
    edited March 2020
    any update on this? The fact that I cant use the FeatureScript on existing bodies where I modified the appearance is rather disappointing
  • Moderator, Onshape Employees, Developers Posts: 1,646
    @victor_ragusila
    If you follow these instructions you can see how to reset part properties:
    https://www.onshape.com/cad-blog/tech-tip-how-to-reset-part-properties-in-onshape
    Unfortunately, color does not show up explicitly in that panel, so you will have to use "Reset all" if you would like to reset the color.
    We will start brainstorming on how to handle this better.
    Apologies, it appears that "Reset all" is the only way to reset any property.  I was misinformed about being able to reset individual properties from the dialog.  For now, it appears that appearance follows the same rules as everything else, and is resettable.
  • Member Posts: 43 PRO
    @ilya_baran , is this still on the horizon?
    It's still on our todo list, but we've prioritized other work ahead of it.  Please make a ticket so your vote can count in the prioritization process.
  • Member Posts: 96 EDU
    Is there any option for resetting the properties of a part in a part studio? I'm setting the properties in FeatureScript and I manually played with the color of a part and now can't find a way to undo that.
  • Onshape Employees, Developers, HDM Posts: 565
    @monroe_weber_shirk
    The "Reset all" button does exactly what you want. This will reset all properties at once (so if you don't want everything reset you'll need to redo those), but it's the one way to completely remove manually-set properties (including color), so after that you'll see your FS properties shining through.
