Issue with loft and matching verticies
It seems no matter which verticie I pick to mate to, the right side face coming from the body tries to connect to the top of the circle. I have no manually placed vert there, nor could I select one at that location. My ideal situation would be that it follows my sketch as a guide, but I realized you cannot select more than one pair of verts to assist the loft in creation. Is there something I am missing here, or is this an intended feature?
I am most concerned about the geometry being symetrical as this is a functional part and will be 3d printed. Any suggstions or help here would be appreciated!
mahir Member, Developers Posts: 1,316 ✭✭✭✭✭
You're right, you can only select one vertex per profile. Don't think of Match Vertices as a vertex-to-vertex map. It's more of a clocking feature that sets "vertex 0" for each profile. The best way to force correct vertex mapping is to make sure each profile has the same number of line segments. It looks like your blue body has 8 segments (4 sides, 2 chamfers, 2 fillets). Instead of using the end of your shaft as the profile, start a sketch on that surface, Use/Convert the circular edge, and use the Split command to segment that circle into 8 pieces. Now when you use the Match Vertices option, the rest of the loft should fall in line.
Here's an example.
https://cad.onshape.com/documents/57acdfaae4b005c413ed9b6f/w/3fd585a46d3af1b3ba413c53/e/d83a0ad59f9f6a2a297dc6e7
6
Here's an example.
