For loop for annotation creation in FS
florianflorian Member, OS Professional Posts: 110 ✭✭✭
My plan: I just wanted to create quick new version of the "Part Number" property example FS.
When I looked at the code I was suprised by the extreme repetition in the code. I think it could be solved with a few small lists. But it seems that the limitation is annotation creation that does not accept for loops.
annotation { "Feature Type Name" : "Part Number" }
export const partNumber = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        ...ORIGINAL CODE...
            for (var i = 1; i <= 3; i += 1)
The original:
https://cad.onshape.com/documents/cb387c60a50e49e2a50a65da/w/38f957562c3238fb6debd3a3/e/c6024f1ff135baf098509c71
My start incl. error: https://cad.onshape.com/documents/6d98f6b9970b451ad1ea02d9/w/f2d80f916670b2e22b04c23d/e/19b6147f5e63fff7f36abbe5
    edited March 2018
    Our approach to handling varying parameter multiplicity in feature dialogs is array parameters. Documentation is here. They do use a for loop, just with slightly different syntax  :)
    I believe Ilya didn't use array parameters in that example because right now, they can't be configured (If you want this functionality, please request it!)
    Not sure it's exactly the same thing as configurable array parameters, but  you can vote for my improvement request for conditional visibility of inputs in array parameters. Making them configurable would fix that, too.
    https://forum.onshape.com/discussion/7628/conditional-visibility-of-array-parameters/
  • florianflorian Member, OS Professional Posts: 110 ✭✭✭
    Thanks for the help! That worked well.
    See the result: https://cad.onshape.com/documents/6d98f6b9970b451ad1ea02d9/w/f2d80f916670b2e22b04c23d/e/be217d6c0f6b483e0594d33a
    Offtopic: However I'm confused with the toString parsing. An isAnything with the value "diameter in mm" will be parsed as "diameter *inch *millimeter" => See entered values in V1 of the doc. Expected "diameter in mm"
    Offtopic 2: Any way to insert whitespace in a partname as separator? I tried setting tefault to " " but it does not work.
    I added two nasty workarounds to get what I want from my two offtopics above. Any ideas for a cleaner implementation are appreciated.
