Boolean add
Member Posts: 5 EDU
Hello everyone,
I want to create a feature script to create simple joint automatically,
I want to "glue" a few parts together but I don't know how to identify the loop-created entities and how to use them in the op boolean
There is also something about the deleted sketch that I can't suppress
If someone has an answer I'll be thankfull, I'm new in the FeatureScript o:)
Here is the code :
FeatureScript 765;
import(path : "onshape/std/geometry.fs", version : "765.0");
annotation { "Feature Type Name" : "My Creneaux GOOD" }
export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        annotation { "Name" : "Face a couper", "Filter" : EntityType.FACE, "MaxNumberOfPicks" : 1 }
        definition.face is Query;
        annotation { "Name" : "Premier de la longueur ?" }
        definition.premLon is boolean;
        annotation { "Name" : "Epaisseur" }
        definition.ep is string;
        annotation { "Name" : "Longueur" }
        definition.long is string;
        annotation { "Name" : "Largeur" }
        definition.larg is string;
        var epaisseur = stringToNumber(definition.ep);
        var creneau = 3 * epaisseur;
        var longueur = stringToNumber(definition.long);
        var largeur = stringToNumber(definition.larg);
        //Premier support
        var sketch1 = newSketch(context, id + "sketch1", {
                "sketchPlane" : /*definition.face*/ qCreatedBy(makeId("Top"), EntityType.FACE)
        skRectangle(sketch1, "rectangle1", {
                    "firstCorner" : vector(0, 0) * centimeter,
                    "secondCorner" : vector(longueur, largeur) * centimeter
        skSolve(sketch1);
        //Deuxieme support
        var sketch2 = newSketch(context, id + "sketch2", {
        skRectangle(sketch2, "rectangle2", {
        skSolve(sketch2);
        /*var sketch2 = newSketch(context, id + "sketch2", {
           "sketchPlane" : qCreatedBy(makeId("Top"), EntityType.FACE)
           skRectangle(sketch2, "rectangle3", {
           "secondCorner" : vector(longueur,largeur) * centimeter
           "firstCorner" : vector(-creneau, -creneau) * centimeter,
           "secondCorner" : vector(longueur+creneau,largeur+creneau) * centimeter
           skSolve(sketch2);*/
        //Premiere partie
        //Lignes sur X
        for (var i = 0; i < longueur / 2 / creneau; i += 1)
            fCuboid(context, id + "cuboid1" + i, {
                        "corner1" : vector(i * 2 * creneau, 0, 0) * centimeter,
                        "corner2" : vector(i * 2 * creneau + creneau, epaisseur, epaisseur) * centimeter
            fCuboid(context, id + "cuboid2" + i, {
                        "corner1" : vector(i * 2 * creneau, 0 + largeur - epaisseur, 0) * centimeter,
                        "corner2" : vector(i * 2 * creneau + creneau, epaisseur + largeur - epaisseur, epaisseur) * centimeter
        //Lignes sur Y
        for (var i = 0; i < largeur / 2 / creneau; i += 1)
            fCuboid(context, id + "cuboid3" + i, {
                        "corner1" : vector(0, i * 2 * creneau, 0) * centimeter,
                        "corner2" : vector(epaisseur, i * 2 * creneau + creneau, epaisseur) * centimeter
            fCuboid(context, id + "cuboid4" + i, {
                        "corner1" : vector(0 + longueur - epaisseur, i * 2 * creneau, 0) * centimeter,
                        "corner2" : vector(epaisseur + longueur - epaisseur, i * 2 * creneau + creneau, epaisseur) * centimeter
        extrude(context, id + "extrude1", {
                    "entities" : qSketchRegion(id + "sketch1"),
                    "endBound" : BoundingType.BLIND,
                    "depth" : -0.01 * centimeter,
                    "operationType" : NewBodyOperationType.ADD
        extrude(context, id + "extrude2", {
                    "entities" : qSketchRegion(id + "sketch2"),
                    "depth" : (0.01 + epaisseur * 3) * centimeter,
                    "operationType" : NewBodyOperationType.NEW,
        extrude(context, id + "extrude3", {
                    "depth" : (epaisseur * 3) * centimeter,
        opBoolean(context, id + "boolean1", {
                    "tools" : qCreatedBy(id + "extrude3", EntityType.BODY),
                    "targets" : qCreatedBy(id + "extrude2", EntityType.BODY),
                    "operationType" : BooleanOperationType.SUBTRACTION
        //Deuxieme partie
            fCuboid(context, id + "cuboid5" + i, {
                        "corner1" : vector(creneau + i * 2 * creneau, 0, 2 * epaisseur) * centimeter,
                        "corner2" : vector(creneau + i * 2 * creneau + creneau, epaisseur, 2 * epaisseur + epaisseur) * centimeter
        /*for (var i = 0; i < longueur / 2 / creneau; i += 1)
           fCuboid(context, id + "cuboid6" + i, {
           "corner1" : vector(creneau + i * 2 * creneau, 0 + largeur - epaisseur, 2 * epaisseur) * centimeter,
           "corner2" : vector(creneau + i * 2 * creneau + creneau, epaisseur + largeur - epaisseur, 2 * epaisseur + epaisseur) * centimeter
        //Lignes sur Y
            fCuboid(context, id + "cuboid7" + i, {
                        "corner1" : vector(0, creneau + i * 2 * creneau, 2 * epaisseur) * centimeter,
                        "corner2" : vector(epaisseur, creneau + i * 2 * creneau + creneau, 2 * epaisseur + epaisseur) * centimeter
  • Moderator, Onshape Employees, Developers Posts: 1,646
    To answer your second question first: Sketches are not deleted/consumed when you use them.  They'll stick around to be used as many times as they're needed.  If you'd like to get rid of them you can do:
    opDeleteBodies(context, id + "deleteSketches", { "entities" : qCreatedBy(id + "sketch1", EntityType.BODY) });
    To answer your first question, you need to use qUnion.  A query for all the loop created cuboids as you have the code now would look like:
    qUnion([qCreatedBy(id + "cuboid1", EntityType.BODY), qCreatedBy(id + "cuboid2", EntityType.BODY), qCreatedBy(id + "cuboid3", EntityType.BODY), ... repeat this all the way to 7]);
    The reason that you don't have to put all the individual "+ i" parts for the ids is because ids are hierarchical, so a parent id also represents the operations of its children.  Using this knowledge, you could simplify your code by having your code look like:
    //////// Do all the setup
    for (...)
        fCuboid(context, id + "cuboidGroupA" + "1" + i, ...)
    for (...)
        fCuboid(context, id + "cuboidGroupA" + "2" + i, ...)
    /////// Do some other stuff
    for (...)
        fCuboid(context, id + "cuboidGroupB" + "1" + i, ...)
    for (...)
        fCuboid(context, id + "cuboidGroupB" + "2" + i, ...)
    const allCuboids = qUnion([qCreatedBy(id + "cuboidGroupA", EntityType.BODY), qCreatedBy(id + "cuboidGroupB", EntityType.BODY)]);
    More reading on id hierarchy here:
    https://cad.onshape.com/FsDoc/library.html#Id
    Another simple way to collect these entities without changing how your code currently looks would be to do this before your first for loop:
    var cuboids = qNothing();
    And then after each for loop:
    cuboids = qUnion([cuboids, qCreatedBy(id + "cuboid<index>", EntityType.BODY)]);
    With <index> replaced with the corresponding number in that for loop.
    Hope this helps!
  • Member Posts: 5 EDU
    Thank you so much for the tips !
    My script is now running well !
    If I can ask another little question, I want to catch the length and the width of a rectangular face, is there a function to do this ? or do I need to catch them by hand ?
    Regards,
    Guillaume
    If the face is XYZ axis-aligned, you could use evBox3d, but it's probably more stable to find the edges you care about and use evLength.
    Thank you for the answer, I found the function and it works well
    Another little question, if you want to get a point coordinates, what is the function related to ?
    The function you are looking for is `evVertexPoint`
    All of the geometry evaluation functions are found in `evaluate.fs` and are documented here:
    https://cad.onshape.com/FsDoc/library.html#module-evaluate.fs
