Copying an extruded entity
Most likely asked before but i cannot fond any direct reference to my question.
I have created and object, extruded it and now i want to replicate it within the same drawing to create a larger pattern of my object.
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
@peter_roberts941
Me or someone else on this forum would be happy to take a look at the issue you're facing if you post the URL of your document in a comment on this thread.Jake Rosenfeld - Modeling Team5
Depending on where you want your duplicates to land, you can use:
Linear pattern: https://cad.onshape.com/help/Content/linearpattern.htm
Circular pattern: https://cad.onshape.com/help/Content/circularpattern.htm
Curve pattern: https://cad.onshape.com/help/Content/curvepattern.htm
Mirror: https://cad.onshape.com/help/Content/mirror.htm
Hope that helps!
https://cad.onshape.com/help/Content/transform.htm
Make sure the "Copy part" option is checked.
These features will help my cause, my next challenge is to get these replications to fix to the face so i can extrude them. What i am finding is that only one or the other will extrude but never all of them.
