how to use mirrorAcross
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
You can mirror across any planar face, so if the part you're mirroring has a good face for that, you can just use that face.
Otherwise, if you have the mathematical description for the plane you want to mirror across, but no actual geometry for it, you can do something like:var mPlane = plane(vector(1, 2, 3) * inch, vector(1, 0, 0)); // <-- just an example, use any plane you want opPlane(context, id + "plane", { "plane" : mPlane }); // <-- creates the construction plane<br>mirror(...); // <-- do the mirror using qCreatedBy(id + "plane", EntityType.FACE) as the `mirrorPlane` opDeleteBodies(context, id + "delete", { "entities" : qCreatedBy(id + "plane", EntityType.BODY) }); // <-- delete the plane so it is not left behind in the Part Studio
https://cad.onshape.com/FsDoc/library.html#plane-Vector-Vector
https://cad.onshape.com/FsDoc/library.html#opPlane-Context-Id-map
https://cad.onshape.com/FsDoc/library.html#opDeleteBodies-Context-Id-map
Jake Rosenfeld - Modeling Team6
Calling mirrorAcross returns a 'Transform' which can be used in a variety of ways. A few examples: a transform could be used in applyPattern() to mirror a part or it can be multiplied by a world space 'Vector' to mirror that vector across the plane in question.
https://cad.onshape.com/FsDoc/library.html#module-transform.fs
The concept is similar to a transformation matrix in linear algebra:
https://en.wikipedia.org/wiki/Transformation_matrix
If you don't want to boolean the result onto the seed, you can just leave out the last 3 parameters.
how to create or get that plane without user selecting the face?
